JadeEyedWolf
Member
Does the Infuse have it or not? I sure do hope so!
If anyone can confirm (or deny) this, that'd be great!
It does support it.
the trick here is that it's not a true microUSB. it has a new standard called MHL (stands for Mobile High-definition Link) that supports full HDMI playback and simultaneous charging through an adapter. I did notice that the units that were given out at the announcement event came with the MHL adapter in the box but I don't know if the retail units will come with one.
hope this helps!
Edit: If you watch the unboxing video on the announcement link they show the Adapter at about 1:20. and this image of the box shows the box contains: "MHL adapter for HDMI output"
So you can have it charging/power supply while using the hdmi to your tv or whatever?
