hdmi output
KingD2013
Seen a lot of stuff on the internet about this but still have not come to a conclusion.
I have the tab 2 10.1 and was wondering if it has a hdmi output?
Thanks for the help but ive also seen a lot of stuff on which versions it will work with?
I have the version GT- P5110, will it work with that?
What is hdmi?
" HDMI is an acronym that stands for High Definition Media Interface. Essentially, HDMI is just a simpler, more accurate way of transmitting data between components. HDMI is an alternative to other connections, such as DVI or component video. The system consists of digital televisions that include HDMI inputs and components (DVD players, cable/satellite boxes and Blu Ray Players) with HDMI outputs. An HDMI cable, which consists of 19 individual wires rolled into a single cable, is used to connect the two. The interface resembles a large USB connection, with 19 pins or holes."
Harry
The only referenced version that really is works consistently is the P5113usa. Model
Your TV must have the hdmi plug as well
