DarthSkirata
Howdy folks!
Let me preface this by saying I am a 48-hours deep Android NOOB, so I apologize if the solution to this is something unbelieveably simple that I have just overlooked. I don't think it is, because I am very experienced with WinMo, BB, and WebOS and don't usually pull NOOB type moves.
So, I have a Droid Eris. Actually, I have two. Well, I have one and she has one, anyway.
I have had no trouble with hooking mine up to the computer with USB, mounting it, and moving files back and forth. One of the first things I did was load files on.
When I try and hook hers up, I plug it in with the same USB cable (one of the cables that came with them, btw), mount it, and nothing happens. It isn't recognized by the computer.
The first time I did this with her phone, I had a little ballon pop up on the task bar that said something about "installing HTC Dream".
If I go to my computer tho, nothing is there that could be the phone.
I checked my device manager in the control panel, and under "ADB Interface" i have HTC Dream listed.
This is as far as I have gotten with this.
This all came about because she couldn't figure out how to set the theme song from the office as her tone for text messaging. I hooked it up to the computer to try and see if I could move the file into a different folder to try and set it, and ran into this f---stick of a problem.
Any and all help is greatly appreciated!
Thanks in advance!
Thanks in advance!
