Head set
Can anyone suggest me a good headset comaptible with galaxy s2 ??
with inbuilt mic and volume control ?
I use Nokia's BH-505 with my s2 and very impressed with them, Great battery life and sound quality is great for the price. With them being bluetooth no more bloody wire as well :)
Can you still listen to the radio with them? (Probably not, but i had to ask!)
If not, is there any way to use Bluetooth headset and be able to listed to the radio from the phone?
No radio dont work.
I listen to alot off internet radio though so dont effect me. Not great if you dont have data plan though :)
I know, that with this set i could listen to the radio:
Plantronics | Pulsar 590A
BUt, they seem to be out of stock just about everywhere.
Also i would prefer something smaller, like earphones, not headphones.
If you saw any, please let me know.
I am currently looking at Ulimate Ears (now Logitech) 200vi and good allround value. Wired ear plugs with button control.
I'm using Blueant Q2. Q2 Smart Bluetooth Headset - BlueAnt Wireless. This one can listen to music too, but for FM you need to use the 3.5MM audio jack for antenna. This bluetooth can connect up to 2 devices at the same time, but the audio function will work on the first device connected. I usually turn off the audio function on my S2, as I use the audio function for a standalone GPS unit.
