Help Headphone problem! No right channel sound!!
Hi,
I am using sennheiser HD 203 head phones, all was well till a while ago, when suddenly my headphone stopped working partially ( sound only came form the left channel and I had to bend/press the connecting jack to make both the channels work). I thought the headphone is at fault, so I tested it in my friends HTC wildfire, and it worked perfectly, both channels. I returned to my IS and plugged in my headphone again, still the same problem, and sometimes it stops detecting that the headphone is plugged in and music comes from the phones speaker instead. I tried using other Ear/Headphone also, same problem.Moreover, the headphone seems to work fine when I press the top Left corner of the phone ( just over the 3.5 mm Jack). Is any one else facing the same problem? And is there a solution to this?
