are these the standard headphones or your own... there has been talk about incompatibilities depending on how many plastic bands you have on the actual jack plug
It's not just about the rings. The trs connection (2 rings) should work fine but some don't. The socket on the desire is designed poorly. It is recessed in such a way that some trs plugs can't insert far enough to get a full connection.
