david12325
Some of you may have noticed this bug but many have probably not encountered. It happens when you plug your headphones into the jack and the audio is not quite as loud as it should be. There are a few fixes to this:
1. Pause the music for 3-5 seconds and hit play. (Works about 1 in 5 times)
2. Unplug the jack wait a second plug it back in wait a second hit play. (Works about 1 in 3 times)
3. Call someone and hang up after the call has connected. (Works about 1 in 2 times)
I noticed this bug occurs when you receive any sort of notification so if you fix the volume and then get a text it will go back down and you will have to do 1 of the 3 solutions to fix it. This is EXTREMELY annoying for me because %95 of the time I have my phone plugged into my car and while i'm driving i'm pulling the plug in and out and pausing the song and calling people and by the time I get where I get to where I need to be it's finally working.
Is there any way to fix this permanently? I have tried using other music players and they all have the same result. I'm hoping it's not a hardware issue and it's a firmware issue. I am currently using tickerguy's CM7, but I noticed the problem in the stock ROM too.
