Help headphones not working
kintal
When I first got my wildfire all worked fine, now any music/games sounds ect will not play out thro headphones, or the supplied wired handsfree phones/headset.
Would have assumed it to be a physical problem with the socket, but making/receiving calls the headset works fine, making me think its more of a software problem?
The phone is recognizing when something is plugged in, with the headset icon, and music playing is cut from the phone speaker, just not then playing out to the headphones..
Any ideas? Anyone else had similar issues?
Ta
Yep i've had the same isssue, Try turning your phone off and then wait for a few mins and then turn it back on again. It worked for me.
Had tried turning it on and off, and didnt seem to sort for me before.. but just tried again while headphones plugged in.. not sure if that did make the difference but sorted and working now.. cheers mate fingers crossed eh :)
Seems to be triggered by going online, or at least something to do with the net connection , could just be coincidence tho. The headphone feed (music playback) just cuts out and only way to get it working back as it should is to turn phone off and back on..
Any ideas anyone.?
Cheers mate, will have a look..
Did notice it happened at least once at the same time as refreshing my twitter fed, will have a look
Ta
