one for your smartypants out there. I have a new (refurb.) and wanted to get a new headset from VZ. Went to the store, worked fine on BAMF109. Then switched back to Blksource AOSP and you have to hit speaker on and off to make work.
Then, wiped everything and loaded brand new Blksource to see if it might be a software/setting conflict. They worked perfectly. So, i have a self inflicted injury...i searched all through the settings on the phone trying to see where I might have the wrong thing selected (plus apps settings - sound, music, pandora etc). Can't figure out where the problem is. Before I go all the way back to square one and reload everything fresh, thought I would see if someone had the easy fix.
SS
SS
