Help Headset volume control
Lupi619
Does anybody know of any app that will allow the headset volume control to work with the HTC inc? I just bought the Klipsch Image S4i headphones with the mic and remote. It was designed for the ipone but I thought it would work for this phone also. The pause and play work, and even answering the phone works. Although all of those are the same button. I can skip forward, depending on the media player I am using, but the volume controls do not work. Does anybody know of any good apps that fix this problem? Maybe a iphone volume control app or something like it?
I did find this app (Headset volume control):
chart
But it is $3, I don't know much about it and there isn't even any comments left by anyone. Does anybody know about this or can help me at all?
chart
If you can skip the tracks with your new headset - it will work.
