Help Heat warning when charging
Hello,
When I charge my Galaxy S2 I see the yellow triangle with ! inside of it.. Sometimes it will flash a thermometer along side it.
I have replaced my usb flex cable. I have also replaced the battery. The problem continues to persist.
My phone is running ICS. I have not rooted it.
With a charged battery my phone will turn on.
I have not found a similar situation.
Thanks.
Mine runs a little warm when I am using the phone and charging at the same time, but never to the point that the warning comes up.
Do you have a lot of apps running when this happens? You might kill a few apps or free up some running processes. Usually this occurs when you have a lot of current going out at the same time a lot of current is coming in.
Just a thought.
Good Luck,
David
hello,
when i charge my galaxy s2 i see the yellow triangle with ! Inside of it.. Sometimes it will flash a thermometer along side it.
My phone is running ics. I have not rooted it.
Thanks.
i guess that's normal i have 2 s2 devices they all have the same thing !
Not a big thing thogh !
Just a thought.
Good Luck,
David
My phone will not turn on because of the temperature warning.
My phone will boot if a charged battery is put in it.
OK. Wow. Yeah. I would be a little concerned. Mine doesn't get that hot, but like I said, it does get warm. Sorry, I have no idea. Is it a Genuine Samsung battery or aftermarket?
-David
