G
Galaxy s6
Guest
My new galaxy s6 gets a little warm on the top left side near camera and this happens after light to medium use , should I be worried ?
It does not get much hot but still I am worried because it gets warm after very light useIt depends how hot it gets. Install an app that displays temperature.
I only worry if I go above about 55°C.
Smartphones can get very hot. All that power and no cooling fan.
A poor carrier signal can cause a lot of heat.
As a rule I'd say if it's comfortable to touch it's probably ok.
Also if it gets dangerously hot the phone should turn itself off
