There are a LOT of people using Helix Launcher as it a part of several of the available Moment themes. Hit the Menu button on the phone with your home screen up then chose Configure.
it is a new launcher for your homescreens. Once you load it play around and look at the varous settings. It is more an experience learning than a teach me learning.
After download, when you first hit the home button a screen should pop up asking with program to use, click on the check box, then select Helix. From now on Helix will be your home screen program. You will have to select it again if there is an update to Helix.
