Root HELLLLP no ideas left on how to fix my f6
I have an f6 and lately it started messing up it boots up but nothing pops up and I get a message saying (possess/application android system has stopped and then it reboots I have tried everything from wiping cache to full os removal and rom flashing but little success on my half please help me again thank you.:saddroid:
If you've already wiped the cache, factory reset and flashed the stock rom without solving the problem, I'm afraid it might be a hardware failure. :(
Download LG Flash Tools 2014. Install all drivers for the F6, download the 10b kdz. Boot into download mode and run the Flash tool as emergency and flash the 10b kdz that should fix your problem.
If one of your parents to temporarily elevate permissions for you so you can get this done, they don't necessarily have to give you admin access. If this is something you'd rather they not know about ... um ... okay.
Not that I'm advocating this, but any PC will work as long as you have admin access. Just remember that anything you do to your phone is your responsibility.
i don't want them to smash the phone b/c its useless and its not a stock rom its experion i believe its a hardware failure
but i am not quiet sure can i use another phone to download it and then flash it on my f6 like a rom?
-thanks for the support-
:thumbsupdroid:
