Root Help a Noob - Clockworkmod recovery screen question
wilcox99
Hello everyone, I recently rooted my Hero using superoneclick, worked like a charm. I downloaded ROM Manager and was looking to start experimenting with ROMs. For starters, I figured I'd load one of the ROMs already preloaded in ROM Manager (free version).
So I downloaded the ROM which seemed to go fine, clicked on it, followed the prompts which eventually led me to reboot into recovery mode via Clockworkmod to "complete the installation." So I got to the reboot screen, here's what it looked like (below). What do I do from here? Where did the ROM download to? How do I "complete installation." Thanks.
Not sure what to do once I reach this screen. It already asked if I wanted to back up the current ROM and wipe, which I agreed to. when I downloaded the ROM it didn't ask me where I wanted to save it to, when I got to this screen I looked in the SD card by clicking "install zip from SD card" and didn't see it there. Where is it?
okay I can get into where the file is downloaded on the SD card:
install zip from sd card>choose zip from sd card>clockwordmod>download/
this brings me to a screen where I can see a downloaded item from "crunchysoft" which was the ROM I downloaded. When I click on it it brings me to another screen that looks like this:
- ROMManagerManifest/
-img/
The first one has "No files found" the second one brings me to another screen:
-ss/
when I click on that it also says "No files found"
Help!
First off, are you using a GSM or CDMA (Sprint style) Hero? Please ignore everything I'm about to say if you're using a CDMA hero ;)
Personally I'm not a big fan of the clockwork stuff. It's not as good at the other recovery menu, amon ra IMO. Plus, who knows where it's pulling it's ROMs from. I would much rather use one recommended by other Hero users.
What are you looking for in a ROM? 2.1? 2.2? With HTC sense or vanilla?
Here you'll find full instructions for using amon ra. It's really easy :)
Get amon ra.img from the link in my post, put it on the root of your sdcard and then skip to this bit,
Xyro said:
Launch RM again and pick the bottom option, to flash amon ra.
