Root Help a noob out. ROMs?
Hello,
I just got a Atrix 4G and rooted it. Now I want to overclock it so it will perform better on my Laptop Dock. To do that I guess I need to install a kernel mod, or install a ROM.
So, if I install a new ROM does it wipe out all my apps and phone settings? Will I still be able to dock my Atrix on it's laptop dock?
Thanks,
Garrett
Hello,
Thanks,
Garrett
Hi there, congrats on the new Atrix.
first, have you unlocked the bootloader yet? if not, then you will want to do that, as i believe all roms require the bootloader to be unlocked.
As far as gingerbread roms go, Neutrino Romv2.7 located here: [CM7 ROM]╰☆╮Neutrino ROM V2.7╰☆╮[16/04] - xda-developers
is THE most stable and best custom rom with a Cyanogen Mod base.
If your looking for new ice cream sandwich roms, then jokers unofficial CM9 rom and stevendeb/thebill have MIUI available here: [ROM] unofficial CM9 by jokersax 4/30/2012 - xda-developers
MIUI.us V4 Atrix Builds by Th3Bill and TeamMotoTegra - xda-developers
If you like motoblur, then Nottach has probably the best custom blur rom out there, i believe it's the final version. it also has webtop over hdmi, meaning you can simply use the hdmi cable provided with the device and plug it into any hdmi display and once toggled in the settings, it will display the webtop on the display instead of having to use the lapdock. it can be found here: [ROM] NottachTrix4G - AIO Aroma Installer 1.3.1 [2.3.6][Blur][Multi-Lang] - xda-developers
most roms for the atrix don't support webtop...as in if you put it on the dock, nothing will happen.
but that's why you would flash a blur based rom if you want to use your lapdock.
yes it will wipe everything, but if you use titanium backup which can be downloaded from the play store, you can backup all your user apps as well as the saved data and then flash the rom, then restore all your apps back to their original state once you've rebooted.
hope that answers all your questions =)
oh by the way, if you use titanium backup (which you should because it's what 99% of root users use) don't backup system settings or system apps because if you start flashing from rom to rom, if you restore the system settings, all kinds of shit will go wrong because those are settings meant for the previous rom you were on. so just backup user apps.
if you need help learning how to use titanium backup, there are TONS of videos on youtube that will teach you how to be a TB (titanium backup) pro! =)
also, if you want to see a bunch of reviews on many of the roms available for the atrix, check out my youtube channel in my signature.
Jared1234 has you covered I am on nottachtrix 1.3.1 with faux123 oc to 1.30 and im running stable and on the Lapdock runs great
will CM9 works all fine on atrix me860 with all functionalities? say fingerprint and phone potal.
I only would need those 2 and I really want to have ICS or maybe Jellybean...
