Hey guys,
Thanks for taking the time.
I rooted the phone by flashing CWM.img and then flashing a ROM through CWM as suggested by a youtube video.
(I flashed oppo real ROM instead of the one in the video)
Problem: I get a white screen when the screen unlocked.Phone works fine until then. White screen needs me to remove the battery
(There are two threads with the similar problems but not one convincing answer)
Whats working:
1) CWM recovery
2) The phone. except for the problem stated above
Here are the things I've tried so far:
1) Changing the ROM: Tried Oppo real, ICS by Sagarwep, restored a stock backup and still face the same issue.
2) Wiping data, cache, dalvik, flashing again and in different sequences.
Method looking forward to trying:
1) Flashing <pls fill in the blanks> using spflash tool. I've had a bad experience flashing the wrong files getting complete white screen which is worse than what i have now. Care center.
Therein lies the problem.
1) I don't know which links to get the files from. There are just too many threads and methods about these. Enough to confuse a noob like me.
-> Please explain in noob proof language and point me to the thread to get the method and files from.
2) Also I am now unable to get spflash to detect the phone. It gives some error everytime and with all three ROMs mentioned above. It worked fine when i flashed recovery the first time.
-> Please let know if there's something I'm doing wrong. I'll keep trying in the meantime.
Your solution
1) Please let know what you think the problem is as i may be looking in the wrong direction
THANKS a ton in advance.
CHEERS!!
Whats working:
1) CWM recovery
Your solution
CHEERS!!
