klyxmaster
I have tons of software from reading forums (even this one), on how to unbrick a phone. the problem I have, is that the when i plug the phone in it will ask to ok the USB connection then i can see whats on the phone. the phone itself, will either stay on the SAMSUNG logo, in which case i will not recognize the USB being plugged in, OR it will get to the usb window and then windows will show me the folder
regardless of the software i use (oden or w/e), it will not recognize the phone as being connected.
There are no forums covering this, so there must be a step i am missing.
what i think happened:
couple years ago i rooted the phone, last week tinkering with new launchers, i used titanbackup to delete the os launcher (by mistake, i hit the ok to fast when scrolling through files to delete).
this causes the phone to now boot (after factory reset, i did do that too), to setup wizard failed.
so I must have killed something else.
so do i have a REAL brick?
if not, how can i get ODIN and other software to see that th ephone IS CONNECTED (bc windows can see it).
