Help after root
djtroy30
Ok, i've read and read and still have issues. I'm rooted and see that I have superuser perm. I d/l rom manager and have clockworkMod recovery. I try and reboot into recovery to do a nandroid back up, but the phone reboots and then a picture of a phone appears with a red rectangle and a ! mark in it. The phone does nothing until I remove battery. What am I doing wrong?
Try flashing alternative recovery in the Rom Manager
I'm having the same problem trying to reboot into recovery.
I rooted using the SuperOneClick method and the version of Rom manager that I have is 2.5.0.6
What gives? all i want to do is flash CM6 :(
Flash the v2.5.0.1 clockworkmod recovery again
I got errors trying those, you think it has anything to do with using the superoneclick root method?
Just a thought, do you have Titanium Backup? Download from the market, go to problems, install busybox. See if that helps
Have you tried manual recovery reboot ??
Yes, Pushing the home button + power button
gives me the same thing, an image of a phone with a red triangle with a ! in the middle.
quite strange, shouldnt you be able to reboot into recovery even without root?
hmm, I'm not sure if my issue was the same as hers, I have superuser installed and seems to be working properly,
However I noticed you posted the .6 build from the HTC site...
think it would be wise to put this on instead of the .7 I have right now, and try to use universalAndroot? Or would that not make much a difference?
Yes because with the build .7 build you can't use the Universal Androot
I'm trying to get back to .6 but its not reading my phone, now I'm really discouraged about all this...
I did this all last night, I went back to stock and put the .7 build on, rooted using the superoneclick method, and havent been able to reboot into recovery mode, thus not being able to install a custom ROM
Are you flashing the .6 build from your PC, that is the only way to do so
You can't Reboot into Recovery without having one installed -
If you used the Super one click you should have one -
You have to flash Clockwork or another recovery -
