I successfully did it. But somehow skipped the activation screen. I have the blue triangle. How can i get back to it?? Or what can i do to activate it. I know its a dumb question but im in a hurry and need a quick fix!! Thanks
Can you dial *228? That will get you activated. If not and you are at the recovery screen then press the search button and do a factory reset. Then activate.
