Help Help again...lol
DaisFlaque
Android Expert
So here is the lowdown... I am running a2sd on skaters mod, have rooted and unrooted several times and flashed cwm about five times, I believe its right, yet I run a2sd and nothing happens... I tried to move devlic catch and it says it will reboot... NOT! then I figured I needed busy box for the su... NOT!lol
Idk what i did wrong, I partitioned AFTER installation of new rom... I should do it before so it can install the rom in the ext.?.... Right...
In can try mounting the sd-ext position. It will format the partition which got it working for me on ctmod 2.5 with koumakernel 1.3
trying now I dont mean to be such a noob but I need to go into CWM for that right? and then go to mounts and storage...
(Error mounting /sd-ext!) Format? or im thinkig just redo from scratch and stock?? I hate the idea but It is possible...
**Update**
As soon as I booted I get orry!
The process com.android.phone has stopped unexpectedly. please try again.
(again and again)
Yes you need to go into cwm for that. so since you're having a new error. Reflash your rom, bot into it. in phone setting unmount your sdcard (after making a backup of it to your computer or w/e) erase and allow the phone to format the sdcard. When that's done reboot into cwm, partition sd card to your liking then mount sd-ext. Reboot into phone and setup a2sd (I assume you're trying to use DT's A2sd?)
Also, are you using a custom kernel? If so what one?
Also note:
DarkTremors a2SD working with 187MoD(H.B.S.)2 & HoneyBread1 only! Just download the mounting script which can be found here:
http://androidforums.com/galaxy-pre...rktremor-a2sd-prevail-updated-11-18-11-a.html
2.6.35.7 Id thought I was on hoark...
heres the specs.....
Model No. SPH-M820-BST
Android Version. 2.3.5
Baseband Version. S:M820.07 x.FA19 (want to "fix" this too)
Kernel Version. 2.6.35.7
Build No. 187-mod Honeybread3
Hardware Version. M820.07
***update*** Sorry I forgot to say I have went back to Honeybread3 for the time being.
When I went to 4 the force close thingy wouldn't let me do crap. lol
