Root Help Again -.-
FluffyFox
OK, so here is my phone as of right now:
Phone: Lg Motion 4G
ROM (Base): Bobz Cm10 5-12
ROM (Baseless): AOKP Unicorn Port
Fixes: All Fixes for Bobz by johnny1111
So my phone still gets above 100 degrees if I'm using it.
Any other solutions that could help lower the temperature?
Hey FluffyFox,
I've moved you over to the all-things-root area for the LG Motion...I'm guessing the root folks might have some suggestions for you re. clocking (over/under, etc.) and/or other options you might explore.
Cheers!
