Help! *ALL* stock notifications and ringers are gone.
mistyinca
Guest
Not turned down, mind you...
GONE.
They aren't available in the lists anymore except for facebook pop.
What I did today:
downloaded isyncr, ran it.
tried to find playlists in native music player. Could not find them.
Isyncr faq said go to applications-manage applications-media storage-clear data-reboot
That did not fix the problem in question.
Re-did the isyncr instructions and resync'd
downloaded mixzing
Then I noticed my notification sound was different. So I went into notifications only to find facebook pop.
What can I do?
thanks
GONE.
What I did today:
downloaded mixzing
What can I do?
thanks
Are u rooted?
No. I'm not. I will probably try and figure out how to do that eventually, since there are a few things that I'd like to change.
I did actually find that a battery pull fixed things. Funny; the boot did not, but the pull did, so for now the problem is solved.
Though I swear it is switching alarm sounds on me.
Glad its solved!
