HELP android market keeps force closing when trying to open
When i try to open the android market on my droid 2 it loads for a second then says it needs to force close i have no idea what to do. Also i am running liberty 1.5
Welcome! My guess is that you should go into settings-applications-manage apps-all- then select android market. There, try making the selection to uninstall the latest update. If that doesn't work, try clear data...
Actually, do the steps in reverse. If that doesn't work, then pm me or ask the question to folks smarter than I am in the Motorola Droid 2 - Android Forums section.
PS: I'm running liberty 1.5 as well and love it. :) I have a droid x.
Thanks for the reply :D i have already tryed clearing the data and that didnt work. but i cant seem to figure out how to uninstall the latest update :/
