Help HELP!!! Answer Feature is ANNOYING
jmp2010
Help! I have had my photon 4g since January 1, 2012. There is an answering feature that is absolutly annoying for use with my bluetooth! when answering a call I not only have to slide the accept/dismiss but when it is connected a female voice asks to accept press 1, to send to voicemail press 2.
Please someone help me on how to remove this feature so I am able to just click my bluetooth without having to fiddle with the phone?
Thanks!
:confused:
Welcome to the forums, jmp!
Let me move this to the photon 4g sub forum so you can get input directly from fellow owners.
Are you using Google Voice integration? If yes, this is coming from Google Voice and you just need to log in and turn it off. If this is the case:
1. Log in to Google Voice.
2. Click the Settings icon on the right side of the screen.
3. Click on the Calls tab.
4. Set Call Screening to Off.
5. Click Save Changes.
Yeah, I had issues with Google voice and disabled it on my phone from my lap top. It gave me the annoying call screening and for some reason wasn't letting my texts pass through to handcent.
