irishjoeyo
My phone is currently rooted and it was done using unrEVOked. I did not apply any custom ROMS; the only change I made was moving the Amazon and VZ Navigator apps.
I selected the option to reboot and install the update when I was prompted to do so, but it just became stuck at a screen that said "Rebooting..." and it never changed. I powered it off and then back on, but the update never applied. I have not been prompted to install the update since then.
I would like to apply the November update using the easiest method. If I have to unroot it, I don't care because root access isn't that important to me. I have read these instructions, but they're incomplete as they don't show you how to actually perform the steps listed, specifically step #1.
Anyone have any suggestions?
