Root Help asap! Revolutionary crashed while downloading recovery
so I hit y (for yes) to download recovery and it crashed. My phone is on the boot screen with revolutionary IS s-off. I tried opening revolutionary again but it wont find my device. what do i do? please help asap!!
Thanks so what should I choose in the bootloader? "Reboot", "Rebootbootloader", or power down?
choose reboot,or power down.
dont panic... if revolutionary doesnt install clockwork the second time,you can easily do it manually(might be better off doing it that way anyway)
download your recovery of choice,rename PG05IMG,place on the root of your sd card,then boot into hboot via power/volume down. hboot will install it for you... this is one of the perks of "s-off" :D
download a recovery from here: http://androidforums.com/thunderbol...0-radios-recoveries-hboot-updated-9-24-a.html
more info on hboot flashing here: http://androidforums.com/thunderbolt-all-things-root/353591-how-some-root-terminology.html
Okay so now I am officially rooted but I'm not sure I downloaded recovery, (I did it in revolutionary again, hit y, and said successful, but then closed. How can I be sure? And how do I know if I have clockwork? It's not in my app drawer
clockwork is your recovery. you can get to it from hboot,from apps like quickboot or rom manager,or from the power off menu of most custom roms.
you will need to boot to recovery via one of those methods,and flash the superuser zip in order to be rooted. there is a link on revolutionarys wiki and at the bottom of the root/unroot sticky at the top of the forum :)
I do have superuser, flashed it, working correctly(I used natemils tutorial). So I'm all good?, I have everything I need? I'm bout to flash Sense Bamf SoaB Sense 3.5 so I just want to make sure everything's all good. Thanks for the help! :D
