Help! Asap!!!!
Sammich98
Hey, so I have a Samsung Galaxy S Vibrant and I downloaded Go Launcher and Neon Blue theme from the app market. I was using Go Launcher and it crashed so now I can't do anything on my phone other than turn it on then the screen turns to black. I'd like to know how to erase the app from the computer with out having to be able to use my phone to erase it. Or how to make my phone able for use again with out having to erase all my previous data.
Thanks,
Sammich98
Did you try a cold reboot (pull the battery)?
I'm going to move this to the Galaxy S forum. maybe a better answer lies there. Good luck.
Welcome to the forums. :)
I'm not too sure about your specific device, but I've done a bit of reading and apparently if you turn the phone on whilst holding the menu button, you'll activate Safe Mode which will allow you to remove Go Launcher via the app manager.
