I've been googling the hell out of this, but I'm exhausted and frazzled and have a non-working phone, and I just need a bit of guidance...*sigh*
I have a Telus HTC Desire. Quite a while ago I rooted it and flashed MildWild. Over time, it's slowly gotten more and more unstable - app crashes, then more frequent ones, then entire device crashes, then settings going missing...my final straw was that the Google Play app just went completely and utterly missing. Finally decided I really just needed to re-flash the damn thing.
After some research, I didn't see anyone else having these sorts of problems with MW, and most were recommending it highly. However, I saw a note I hadn't seen previously that ext4 partitions on the SD card for a2sd shouldn't be bigger than 1.5GB, as it might cause instability. So I thought hey - I'll reformat the partitions, make my ext4 the recommended size (it was too big), and just re-install my apps from scratch just in case it was weird data from my backup that was causing problems.
Used MiniTool Partition Wizard to reformat - FAT32 partition first, then ext4 of 1.5GB. Put the ROM zip on the card, and then booted into the bootloader (I put ClockworkMod on there back when I originally played around with it). When I told it to choose a zip from the sdcard, though, it's telling me "E: Can't mount /dev/block/mmcblk0 (or /dev/block/mmcblk0p1) (Invalid argument)" then "E: Can't mount /sdcard"
When I try to reboot it's just going to fastboot, and all I can do from there is reboot again, go to the bootloader again, or power down.
I've seen lots of references to RUUs and such, but then I see a lot of references to that not being the way to go (plus, I don't think I can make a goldcard in the state it's in right now).
I really have no idea what to do to have a functional phone. Can anyone please help?
Info from bootloader is:
BRAVO PVT3 SHIP S-ON
(and that really confuses me, because shouldn't it have been off to have rooted and flashed in the first place? I also can't get it turned back off - Revolutionary just tells me "waiting for device")
HBOOT-0.93.0001
MICROP-051d
TOUCH PANEL-SYNT0101
RADIO-5.17.05.23
Aug 10 2010,17:52:10
I don't care if I go to something custom or stock or what at this point - I really just need a functional device.
Thank you!
HBOOT-0.93.0001
MICROP-051d
RADIO-5.17.05.23
Thank you!
