Root {HELP} Battery Issue
I am running 2.3.6 rooted, removed all bloatware, and excess apps, basically I'm running really light right now. But back to the issue, My admire, when I plug it in it says its
There have been many reports of Admires saying they are charging when they aren't. Mine used to do it a lot, but not as much these days. The port on the bottom can become loose and gets a connection that makes it think its charging when its not. Try wiggling it around a little and see what happens.
I did what you had advised but it's still not working(charging I should say) But it's all good.. I'm about to go to the Corp. Metro Store to get a replacement. Because I use my phone a lot throught the day and the constant battery dying because it never reaches full charge anymore is ridiculous... Since I have insurance might as well cop a virgin admire ;)
Sounds like either a bad battery, or a faulty cold solder on the usb connector.
Either way, if u have insurance, exchange is the answer.
Yea.. I figured that's what it might be... But I didn't get a new one yet.. I went too late to the store lol. I'm about to go soon though and hopefully I won't ever encounter this issue or I'm upgrading :p
