Root [HELP] Battery Notification help
CCallahan
Hoping this is the right place to post this.
Running HTC Supersonic with 2.2 and Sense rom w/3.70 base. The rom is packaged with standard horizontal battery w/% number. I'm trying to change the battery to a vertical or round. The graphic files are easy enough to change but when doing so the icon disappears when usb cable is unplugged from phone (or vice versa..has done it both ways). So currently when I view it, without the usb plugged in, the icon is gone. As soon as I plug the cable in, it shows up correctly.
Need to find out what else I need to modify in order for these to show up properly. Tried flashing an upright battery mod but that didn't help.
Thanks.
