Root Help! Black Screen!
Alright so I rooted my shift, everything was going great. I put on the cyanogenmod rom at first and then decided I wanted to try out a different just to see the differnces. So I then put on evervolv and i found that it was really slow compared to the cyanogen so I put the cyanmod back on. After i did that I found that there was not an android market on so I restored from a back up to my original settings and tried to put the rom back on. When I did it finished and it popped up as a black screen. Now the black screen won't go away and I'm getting pretty worried. Any ideas?
yeah I can go into recovery and i tried reflashing. There's nothing left on my sd card though and I tried to do the full wipe and now it just get's stuck on the htc load screen.
There's nothing left on your SD card..? Sounds like you may have corrupted a file somehow. I would download a ROM on your pc, place a your SD card (may want to consider getting a new one) then flash away. If all else fails run the ruu and return to stock.
