Root Help Bricked C811
eman916
Hi all,
I've been playing around with unlocking my bootloader for my Casio C811 so I can use a GSM sim card. I tried an app called E-Z Unlock and after I rebooted my phone it won't boot. I can connect it to my PC (win7) and it reads it as a CDROM with a folder called IMAGE but my screen is still off.
Is there a way to recover from this brick? I have access to a Ubuntu machine if I have to use adb shell to recover.
Thanks in advance!
~Eman
This phone has no locked bootloader, it has no network lock neither. So you shouldn't install nothing to use a foreign sim. In a nutshell if you want to use this phone in any gsm network around the world you just install your SIM card and that's it. You'll also need Doctoror's apk in order to enable incoming calls, that apk you'll fine here in this forum.
Coming back to your issue if you don't have cwm installed then your only hope is a factory reset from stock recovery.
What if the phone doesn't even boot up at all? I've tried all the key combos with the power button. And when I connected it to my Ubuntu laptop it gave errors when trying to adb to it. But windows 7 sees a folder named IMAGE when I connect it to USB.
