steevo92123
I hope someone can help - love my Cappy, but the past 3 days have been H^&&.
Long story short (you can read what happened in the long version below) My Captivate has the ....phone...triangle...pc icon on the screen. The volume and power reset doesn't work. The remove battery, etc...doesn't work. I've scoured pages and pages to try and figure it out. I made a jig to try and get it into download mode, and the jig works, but it never goes into D/L just that stupid phone icon.
Am I looking at sending this thing back or is there someone out there that can give me back my sanity??
Thanks
It all started when I tried to apply Lag Fix - I know, what was I thinking? Well that kinda failed: Missing icons; when I pressed home it would always ask which Launcher I wanted to use, even thought I would check the "use this..." then after it loaded my choice, I would have missing programs until I clicked on Amazon App Store (probably a coincidence) then my apps would return.
Ok day two: After total frustration with that I tried to reset the phone to "Stock out of the Box" using the Factory Reset Option. It reset to factory (so I thought) so I reinstalled all of my apk's. After reinstalling them I reset the phone and it wouldn't recognize my USB connection. Upon restart it saw it, but when I dragged down the toolbar it would freeze the phone....on and on. Reset to Factory again and did the same procedure.
Day Three: Tried to reinstall Froyo using ODIN and it locked up when it went into Restart mode. Stuck in "factory restore mode".
Thanks
