Root Help ! Bricked Triumph !
Its not bricked, its bootlooping. Brick is when the phone cant boot, get into recovery, and cant see anything(cant see the Motorola Logo).
Also, that kernel has two versions, a stock Froyo version and a CM7 version. Next time make sure you download the right one..
Restore a nandroid backup, one from a thread in the triumph section, or a backup of your own.
I was running Tickerguy's CM7 and i accidentally flashed a stock ROM kernel on it (this one: http://androidforums.com/triumph-al...-bkernel-cm7-dev-0-3-11-16-a.html#post3379256) All i get now is the red motorola logo. Cant fastboot or boot into recovery. Can anyone help me with this ? Thanks in advance!
ok first... your not bricked :D you phone is boot looping.
Steps to fix:
#1- pull phones battery
#2- with battery out plug phone into power source (this stops the phone from automatically booting up when in a boot loop)
#3- unplug the phone
#4- attempt to boot into recovery, and reflash cm7 to get the right kernel back.
EDIT: if you have any problems feel free to pm me! i will help you to the best of my abilities
It isn't hard to get into recovery, just hold the other buttons before you hold the power button, and hold for 15 seconds.
yea but sometimes when the triumph boot loops and you pull the battery, and replace the battery. the phone will power itself back on. and my little trick i posted fixes that.
Ziggy46 it totally worked man ! thanks . And Austrie I wasn't able to get into recovery that way. But thanks both of you for your quick responses !
your welcome! just be careful next time... because you might actually brick your phone if your not cautious :D
I don't bootloop(make mistakes when it comes to flashing anything) so I shouldn't know that, but that is weird though.
yea it is wierd though... i usually only bootloop from making stuff that wont boot right on my phone. then i restore system from my nandroid and retry my creations :D
