iMethod
Member
Okay well im running Calkulin's EViO 2 v1.8 and i really really love this ROM but im having a little problem i would like some help with.
Everytime i restart my phone it just sits at the white HTC EVO 4G screen forever it never boots...Any help? Ill just tell you a little info of what i did so yall know.
I flashed Calkulin's ROM with Amon_Ra and did a full system wipe before hand and then i also installed netarchy-toastmod-bfs-havs-nosbc-universal.
And just to let you know i did install the ROM before the kernal, I have also installed just the ROM and no kernel and it still gave me the problem so i know it cant be the kernel ( or is it?) and then i went onto XDA and it said if it freezed at that screen that maybe deleting the undervolt would fix the problem so i installed the .zip from the XDA website and still doesn't want to boot );
Can anyone help??
Are there any similar ROM's that are just as fast and look nice like this one?
Can anyone help??
, kings Rom is awesome I like it a lot. But I really really like calkulins evio 2 v1.8 with toast kernel the one I told you about but calkulins Rom was giving me a lot of problems ): it would work fine but then when I would power off my phone and turn it back it would never pass the white HTC screen I waited hours it would just reset... and then it finally killed my battery and my phone wouldn't charge/turn-on/or open recovery
, I'm definitely going to try that one out. How is it performance wise and what kernel do you recommend for mik3D?
