I need some help I downloaded warm twopointtwo 3.5 and tried to flash it to my phone several times with no luck. I wiped the phone, and both cashe wipe. I get an error message saying: Wrong digest
System/app.HTC.musicwidget.apk.
Can someone please help this is my first Rom flash
I did use unrevoked with S-offCan you be more specific and give us some info?
DId you use unrevoked to root and are you S-OFF?
AMOLED or SLCD screen?
What HBOOT are you on?
Are you using ROM mngr or Recovery to flash and if the latter then what version of recovery?
O to answer the question of recovery I am using clock work 3.5.1.2 I believe. It the latest version. However I did have to use quicktools to enter recovery to do nandroid and wipein addition to above,what download did you use? theres one for clockwork 2.5.x.x and one for clockwork 3.x.
assuming the answer to "what recovery are you using?" is clockwork,what version?
i wasn unable to flash warm with RA_GNM,so if thats what youre using that may well be your prollem. i forget the specific error messages i got when i tried to flash it.
ultimately,i used the 3.x download and clockwork 3.0.0.8 to get it to work.
Ok ill try that but do i need s-off to flash the warm twopointtwo? Cause i believe i dont have s-off. I think before i move forward with a rom i am gonna unroot and then reroot just to make short everything is straight. Because the first day i rooted i was not able to create a nandroid backup. Or wipe. Had to use rom manager. And from talking to others they say i should not have to do that. Is this true.
On a positive note i thank u scott, kidhudi, and jbdan for the help.
