MapleShosho
Hello, I cannot create a nandroid backup. I have the droidxbootstrapper and rom manager installed. Everytime i try to make a backup it says cannot mount sd card and will not continue on, any tips?
This is what it says everytime i try to create one:
ClockworkMod Recovery v2.5.0.5
Waiting for SD to mount (20s)
SD Card mounted....
ROM Manager Version 2.5.0.7
E:Can't mount /dev/block/mmcblk0 (or dev/block/mmcblk0p1
(Device or resource busy)
Can't mount /sdcard
E: Can't mount /dev/block/mmblk0 (or /dev/block/mmcblk0p1)
thats what i get.
it used to work all the time on 2.3.15
SD Card mounted....
Can't mount /sdcard
thats what i get.
