Root Help? can't get into recovery
flashed BB froyo v021, didn't work kept looping, tried several times. then tried jrummy's kangarade. i'm getting all this weird stuff like apps disappearing, and worse, can't get into recovery.
anyone know how to fix this?
tried clockwork, then SPrecovery
thanks,
rlr
thanks,
rlr
Did you format all the partitions before you installed Froyo? (boot, system, data, cache)
Also you might have to flash back and forth between SP Recovery and ClockworkMod Recovery a few times to get it to work. A LOT of people have been having these weird problems.
And, finally, as for apps disappearing, well, it sounds like Pete's BB *did* make it on there - and if you didn't do like nStallion said, then it is probably moving apps to your SDCard...
