i was trying to flash mimocans lag fix to my phone with odin, but halfway through my laptop died. now it shows a screen with an exclamation point between a phone and a computer. how can i get back to download mode?
And for everyone else reading this...if you didn't understand what I was talking about, that's a pretty good indication you shouldn't be doing things in recovery mode just yet.![]()
I just told you how to get to download..if you see the little phone, a line and a little computer with the exclamation point in it when you try to power on normally, you're not totally bricked, you're just a bit hosed.
Read my instructions again, THAT is how you get to Download mode (big triangle with a shoveling Android). From there you can try flashing with Odin again.
There is NO WAY to get back to the Captivate firmware at this point (until somebody builds a ROM), but you can flash the Vibrant firmware (.pit and PDA only!) and get (mostly) running again.
If you just copied an update.zip, went into recovery and ran it, and that's why you're bricked, I can understand you not knowing what Odin is. Go to XDA's i9000 development forum, read the 'how to' on flashing the Galaxy S, it's the same process for the Captivate. Links to all the software you need are there.
Check here for the stock rom: [Download] Stock Firmware Odin3 Flasher - xda-developers
There is a way to get to stock now:
it doesnt seem to be workingwhen i flashed with odini had to nenter download mode with adb. very weird
yea device was totally bricked, traded back into at&t, now new device is being flashed via odin but stuck at 1 part the factoryfs.rfs
I can get it to Download mode (big yellow triangle), but it's not recognized by Windows XP or Linux after that.
