Help HELP: captivate stuck at boot after clockworkmod install
dolhop
Hi all, hope you can help. I installed clockworkmod recovery onto my wife's captivate, and now it won't boot - it's stuck at the "galaxy-S" screen.....I can get it into the YELLOW TRIANGLE screen and once managed to get it into the clockworkmod menu screen.
I believe the phone has android 2.3, not 2.2 on it and this might have been my mistake. The entry point into the kernel is likely different...
how can i fix this? do i need to remove clockworkmod and go back to the stock bootloader? The phone is not rooted, yet (that was the next step).
I haven't been able to find anything in the forums about people that have done (the stupid thing that I did) and installed clockworkmod on a 2.3 phone.
Thanks.
