help changing rom
To be absolutely clean, you should probably take it back to stock. [Heimdall][Odin][Stock][Root]UCKH7/KK6 Return/Unbrick to Stock (or Root) - xda-developers
You could use Odin and try flashing the kernel you used to root to see if it will get your custom recovery back, but honestly, i'd put it back to stock and start over.
Odin back to stock, definitely. Always better to be safe then sorry. I mean rerooting takes all of two seconds. When there are multiple variants of your device, always double and triple check that what you are flashing is specifically for your device.
