Root Help choosing ICS ROM for Skyrocket
pookieguy
Hello all,
Wondering if you guys can help me decide whether to flash an ICS ROM or not?
I have my Skyrocket tweaked and set up perfectly. It contains...
Version: 2.3.5 (refuse to upgrade to 2.3.6 due to many issues I see some are having)
Kernel: 2.6.35.11+ (excellent "stock-ish" ROM from romracer)
Launcher: Go Launcher EX
Phone is rooted and like to use CWM.
With that said, I'm wondering what is the best option to try? My main concern is obviously performance and battery life. I have spectacular battery life right now and don't want to lose it by flashing an ICS ROM.
Perhaps something that will work with the romracer kernel? For example, something that would still allow me to use CWM and MUST also support boot animations and BLN support. That is a must for me, as I use it to tweak my battery life quite a bit.
Anyways,
Any suggestions would be greatly appreciated.
Thanks,
--mike
