Was fiddling around with some of the options and had a quick question about the "Location Setting" option under Settings->Location.
I have Location 'off' as indicated by the compass with slash-through in notification bar.
However, when I turn GPS on, it can still find my location. I test this using Maps and "My Location" and then it centers to my exact spot.
If I turn GPS off, leave Location off, but click on Wireless Networks to determine location, hitting "My Location" in Maps gets me close to, but not my exact location.
As I understand it, this is because GPS is using the GPS satellites while Wireless Networks just uses the towers.
Now when I turn GPS off AND Wireless Networks off (under Location in Settings), Maps cannot find my location at all.
So that much I understand.. the differences between GPS and using Wireless Networks to determine location...
I don't understand what the "Location On" setting does at all then. When I click it on, it brings up a disclaimer page about using GPS, etc. etc. and then the compass in notification no longer has slashthrough.
But clearly I can still use GPS and/or Wireless networks to determine my location even when "Location" is set to off (compass is slashed through).
Can someone explain to me what "location" does (compass icon)?
Sorry for being long-winded. just wanted to be clear.
Thanks
Thanks
this is kind of bass-ackwards!
