Root Help! CM10 external SDcard as Internal?
Can anyone find a way to get the external sdcard working as the internal Sdcard on CM10? The Script manager app doesn't seem to be working on it :( It's the only thing keeping me from using it and I really want to use it!! :) thanks
If you have your sdcard formatted with an ext partition just for apps, try link2sd. I used it before on the stock rom but haven't tried it on CM10.
As for the internal swap....don't think it's gonna work as of yet.
