Root [HELP] CM9 Roaming
You can try turning your radio off then on again. In the dialer, type *#*#4636#*#* then choose phone options and turn radio off. Wait a minute or so then turn it back on. If that doesn't work, you could wipe /data although that will wipe *all* your data. You would have to redownload apps, etc.
You just saved my phone. Thanks so much! :) I've sat here and flashed the cab file and all. Now I gotta root unlock bootloader etc... Wow. :D But I cannot thank you enough! :)
