IMUcarmen
Android Expert
Last night my phone went into roaming mode though I hadn't turned it on, I'm not sure what happened because I haven't messed with the radio at all. I ended up going to bed with it roaming and this morning I was able to get data working again by dirty flashing cm9. I thought all was well until later in the day I tried sending an sms and they wouldn't go through. Then I tried to make a phone call and it wouldn't go through. So I restarted and my phone went back into roaming mode.
Then I decided to wipe data and flash cm9, but that didnt work
Then I wipe data and flashed playfulgods SOTARD stock ics rom, and that to was stuck in roaming
Then I flashed back to cm9 and took a nap
I was finally able to get my phone working again but the thing is I didn't really do anything. I just sat in settings turning data on and off, turning airplane mode on and off, going into the hidden menu settings and turning radio on and off, changing the default radio setting from cdma only, to lte / cdma only. I just kept changing settings and it finally came back and now my phone, messaging, and data all work again (but for how long I don't know).
I hope someone can make some sense of this because it makes no sense to me at all.
