HELP! Constant Re-Boot!
SportsPT
Need a little help here...out of the blue today my phone started continuously re-booting itself. Only gets to the HTC screen and then re-boots. I have done multiple battery pulls with no results. I cannot boot into recovery either, tried that many times as well. My only option is a screen that I have not seen before that asks if I want to clear all data and then reset the device. Anyone have an ideas? Running Fresh 2.3.3, had no previous problems.
By pulling the battery to kill the boot loop, then holding home and re-starting phone. The phone then re-boots and the loop continues.
I can get into HBOOT, but can't restart into recovery that way either, just boot loops. My only options are FASTBOOT and HBOOT.
Clear data is ok if screen with skateboarding androids. Then reboot and it'll let you in to recovery.
