jj14x
Android Expert
Glad to hear something worked, but you really should continue investigating what is causing these deletes. This (calendar entries or contacts being deleted) is definitely not normal.
Personally, I'd be worried that there is either a rogue/badly-coded third party app, or that access to the account has been compromised. Do you have two-factor authentication set up? If not, do consider it.
