Help HELP!! crash crash crash
aldrs
Almost anything i do i get "...has stopped unexpectedly".
few examples:
com.android.mms
com.android.phone
com.android.browser
com.android.settings
can't even enter the settings to poke around cas it crashes instantly...
now what...
Are you rooted and on a custom ROM? Have you installed any recent apps that you suspect could be the problem?
I've had this happen a couple times flashing ROMs or new kernels.
If you haven't done any of those, can you boot into recovery and perform a factory reset? That's likely your best bet at this point.
Also, welcome to the forums!
Yeah well i did a hard reset and that fixed it.
Do not have any clue what was the cause.
Didn't install anything change any settings etc. It's just weird O.O
